Time Before: 0.02989 seconds
Time After: 0.04152 seconds
Time Taken: 0.01164 seconds
Time Before: 0.04163 seconds
Time After: 0.04208 seconds
Time Before: 0.04236 seconds
Time After: 0.04254 seconds
Time Before: 0.04328 seconds
Time After: 0.04580 seconds
Time Taken: 0.00252 seconds
Time Before: 0.04261 seconds
Time After: 0.05019 seconds
Time Taken: 0.00758 seconds
Time Before: 0.06106 seconds
Time After: 0.06150 seconds
Time Before: 0.06398 seconds
Time After: 0.06521 seconds
Time Before: 0.06042 seconds
Time After: 0.06538 seconds
Time Taken: 0.00496 seconds
Time Before: 0.10630 seconds
Time After: 0.10653 seconds
Time Before: 0.13775 seconds
Time After: 0.13903 seconds
End call of global.php: 0.14156198501587
Time Before: 0.15287 seconds
Time After: 0.15305 seconds
Time Before: 0.15573 seconds
Time After: 0.15720 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=84109'
Time Before: 0.17689 seconds
Time After: 0.17719 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.17573118209839 seconds with 9 queries, spending 0.0082926750183105 doing MySQL queries and 0.16743850708008 doing PHP things.
