Time Before: 0.00139 seconds
Time After: 0.00189 seconds
Time Before: 0.00196 seconds
Time After: 0.00257 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00287 seconds
Time After: 0.00299 seconds
Time Before: 0.00377 seconds
Time After: 0.00629 seconds
Time Taken: 0.00252 seconds
Time Before: 0.00304 seconds
Time After: 0.00971 seconds
Time Taken: 0.00666 seconds
Time Before: 0.01147 seconds
Time After: 0.01189 seconds
Time Before: 0.01504 seconds
Time After: 0.01729 seconds
Time Taken: 0.00226 seconds
Time Before: 0.01085 seconds
Time After: 0.01746 seconds
Time Taken: 0.00661 seconds
Time Before: 0.02232 seconds
Time After: 0.02245 seconds
Time Before: 0.02439 seconds
Time After: 0.02561 seconds
End call of global.php: 0.027243137359619
Time Before: 0.02881 seconds
Time After: 0.02895 seconds
Time Before: 0.03103 seconds
Time After: 0.03246 seconds
SET lastactivity = 1785348920, location = '/forums/private.php?do=newpm&explain=1&u=84287'
Time Before: 0.04522 seconds
Time After: 0.04558 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.044181108474731 seconds with 9 queries, spending 0.0092153549194336 doing MySQL queries and 0.034965753555298 doing PHP things.
