Time Before: 0.01899 seconds
Time After: 0.02867 seconds
Time Taken: 0.00968 seconds
Time Before: 0.02876 seconds
Time After: 0.02951 seconds
Time Taken: 0.00074 seconds
Time Before: 0.02976 seconds
Time After: 0.02988 seconds
Time Before: 0.03063 seconds
Time After: 0.03300 seconds
Time Taken: 0.00237 seconds
Time Before: 0.02995 seconds
Time After: 0.03727 seconds
Time Taken: 0.00731 seconds
Time Before: 0.04734 seconds
Time After: 0.04755 seconds
Time Before: 0.05051 seconds
Time After: 0.05191 seconds
Time Taken: 0.00140 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.04660 seconds
Time After: 0.05212 seconds
Time Taken: 0.00552 seconds
Memory After: 2,261.719 KB
Time Before: 0.08397 seconds
Time After: 0.08411 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.10332 seconds
Time After: 0.10472 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.11168 seconds
Time After: 0.11182 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.11402 seconds
Time After: 0.11550 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=84297', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.13567 seconds
Time After: 0.13601 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
