Time Before: 0.02193 seconds
Time After: 0.02949 seconds
Time Taken: 0.00756 seconds
Memory Before: 533.906 KB
Memory After: 559.023 KB
Time Before: 0.02960 seconds
Time After: 0.03003 seconds
Memory Before: 558.961 KB
Memory After: 559.969 KB
Time Before: 0.03026 seconds
Time After: 0.03041 seconds
Memory Before: 560.523 KB
Memory After: 561.047 KB
Time Before: 0.03121 seconds
Time After: 0.03456 seconds
Time Taken: 0.00336 seconds
Memory Before: 563.648 KB
Memory After: 564.570 KB
Time Before: 0.03049 seconds
Time After: 0.03930 seconds
Time Taken: 0.00882 seconds
Memory Before: 560.297 KB
Memory After: 1,641.297 KB
Memory Used: 1,081.000 KB
Time Before: 0.04844 seconds
Time After: 0.04880 seconds
Memory Before: 2,136.141 KB
Memory After: 2,136.758 KB
Time Before: 0.05189 seconds
Time After: 0.05314 seconds
Memory Before: 2,148.320 KB
Memory After: 2,148.180 KB
Time Before: 0.04763 seconds
Time After: 0.05339 seconds
Time Taken: 0.00576 seconds
Memory Before: 2,128.320 KB
Memory After: 2,261.203 KB
Time Before: 0.08725 seconds
Time After: 0.08740 seconds
Memory Before: 2,814.781 KB
Memory After: 2,815.297 KB
Time Before: 0.11203 seconds
Time After: 0.11329 seconds
Memory Before: 2,903.117 KB
Memory After: 2,903.711 KB
End call of global.php: 0.1157021522522
Time Before: 0.12283 seconds
Time After: 0.12299 seconds
Memory Before: 3,539.836 KB
Memory After: 3,540.266 KB
Time Before: 0.12587 seconds
Time After: 0.12798 seconds
Time Taken: 0.00211 seconds
Memory Before: 3,821.367 KB
Memory After: 3,823.055 KB
SET lastactivity = 1788869663, location = '/forums/private.php?do=newpm&explain=1&u=8433'
Time Before: 0.14776 seconds
Time After: 0.14806 seconds
Memory Before: 4,295.195 KB
Memory After: 4,295.414 KB
Page generated in 0.14681506156921 seconds with 9 queries, spending 0.0095305442810059 doing MySQL queries and 0.13728451728821 doing PHP things.
