Time Before: 0.00222 seconds
Time After: 0.00275 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00282 seconds
Time After: 0.00339 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00360 seconds
Time After: 0.00373 seconds
Time Before: 0.00441 seconds
Time After: 0.00719 seconds
Time Taken: 0.00278 seconds
Time Before: 0.00378 seconds
Time After: 0.01056 seconds
Time Taken: 0.00679 seconds
Time Before: 0.01241 seconds
Time After: 0.01266 seconds
Time Before: 0.01510 seconds
Time After: 0.01640 seconds
Time Before: 0.01182 seconds
Time After: 0.01657 seconds
Time Taken: 0.00475 seconds
Time Before: 0.02159 seconds
Time After: 0.02172 seconds
Time Before: 0.02360 seconds
Time After: 0.02488 seconds
Time Before: 0.02769 seconds
Time After: 0.02786 seconds
Time Before: 0.02988 seconds
Time After: 0.03133 seconds
UPDATE session SET lastactivity = 1782850389, location = '/forums/private.php?do=newpm&explain=1&u=84354' WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.04392 seconds
Time After: 0.04424 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
