Time Before: 0.00193 seconds
Time After: 0.00263 seconds
Time Taken: 0.00070 seconds
Time Before: 0.00274 seconds
Time After: 0.00321 seconds
Time Before: 0.00361 seconds
Time After: 0.00375 seconds
Time Before: 0.00479 seconds
Time After: 0.00730 seconds
Time Taken: 0.00250 seconds
Time Before: 0.00383 seconds
Time After: 0.01205 seconds
Time Taken: 0.00822 seconds
Time Before: 0.01480 seconds
Time After: 0.01521 seconds
Time Before: 0.01756 seconds
Time After: 0.01878 seconds
Time Before: 0.01402 seconds
Time After: 0.01895 seconds
Time Taken: 0.00493 seconds
Time Before: 0.02546 seconds
Time After: 0.02559 seconds
Time Before: 0.02935 seconds
Time After: 0.03067 seconds
Time Taken: 0.00133 seconds
End call of global.php: 0.032315015792847
Time Before: 0.03419 seconds
Time After: 0.03436 seconds
Time Before: 0.03632 seconds
Time After: 0.03776 seconds
SET lastactivity = 1785276083, location = '/forums/private.php?do=newpm&explain=1&u=84412', badlocation = 1
Time Before: 0.05026 seconds
Time After: 0.05067 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.049322128295898 seconds with 9 queries, spending 0.0082235336303711 doing MySQL queries and 0.041098594665527 doing PHP things.
