Time Before: 0.00223 seconds
Time After: 0.00284 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00291 seconds
Time After: 0.00330 seconds
Time Before: 0.00356 seconds
Time After: 0.00369 seconds
Time Before: 0.00462 seconds
Time After: 0.00750 seconds
Time Taken: 0.00288 seconds
Time Before: 0.00377 seconds
Time After: 0.01248 seconds
Time Taken: 0.00871 seconds
Time Before: 0.01503 seconds
Time After: 0.01544 seconds
Time Before: 0.01828 seconds
Time After: 0.01952 seconds
Time Before: 0.01426 seconds
Time After: 0.01977 seconds
Time Taken: 0.00552 seconds
Time Before: 0.02660 seconds
Time After: 0.02672 seconds
Time Before: 0.02924 seconds
Time After: 0.03049 seconds
Time Before: 0.03340 seconds
Time After: 0.03355 seconds
Time Before: 0.03617 seconds
Time After: 0.03765 seconds
UPDATE session SET lastactivity = 1789061037, location = '/forums/private.php?do=newpm&explain=1&u=84548' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05437 seconds
Time After: 0.05464 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
