Time Before: 0.00195 seconds
Time After: 0.00248 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00258 seconds
Time After: 0.00315 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00339 seconds
Time After: 0.00351 seconds
Time Before: 0.00426 seconds
Time After: 0.00665 seconds
Time Taken: 0.00239 seconds
Time Before: 0.00356 seconds
Time After: 0.01016 seconds
Time Taken: 0.00660 seconds
Time Before: 0.01214 seconds
Time After: 0.01267 seconds
Time Before: 0.01412 seconds
Time After: 0.01577 seconds
Time Taken: 0.00165 seconds
Time Before: 0.01155 seconds
Time After: 0.01594 seconds
Time Taken: 0.00438 seconds
Time Before: 0.02146 seconds
Time After: 0.02160 seconds
Time Before: 0.02383 seconds
Time After: 0.02513 seconds
Time Before: 0.02814 seconds
Time After: 0.02829 seconds
Time Before: 0.03040 seconds
Time After: 0.03199 seconds
Time Taken: 0.00159 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=84744' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.04479 seconds
Time After: 0.04506 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
