Time Before: 0.01801 seconds
Time After: 0.02308 seconds
Time Taken: 0.00507 seconds
Time Before: 0.02318 seconds
Time After: 0.02352 seconds
Time Before: 0.02377 seconds
Time After: 0.02390 seconds
Time Before: 0.02465 seconds
Time After: 0.02719 seconds
Time Taken: 0.00254 seconds
Time Before: 0.02397 seconds
Time After: 0.03184 seconds
Time Taken: 0.00786 seconds
Time Before: 0.03906 seconds
Time After: 0.03934 seconds
Time Before: 0.04125 seconds
Time After: 0.04249 seconds
Time Before: 0.03848 seconds
Time After: 0.04269 seconds
Time Taken: 0.00421 seconds
Time Before: 0.06908 seconds
Time After: 0.06922 seconds
Time Before: 1.39247 seconds
Time After: 1.39415 seconds
Time Taken: 0.00168 seconds
Time Before: 1.40941 seconds
Time After: 1.40963 seconds
Time Before: 1.41300 seconds
Time After: 1.41444 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=84758' WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 1.43383 seconds
Time After: 1.43411 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
