Time Before: 0.02787 seconds
Time After: 0.03407 seconds
Time Taken: 0.00619 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.03417 seconds
Time After: 0.03476 seconds
Time Taken: 0.00059 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.03505 seconds
Time After: 0.03522 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.03606 seconds
Time After: 0.03927 seconds
Time Taken: 0.00321 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.03530 seconds
Time After: 0.04455 seconds
Time Taken: 0.00925 seconds
Memory Before: 560.883 KB
Memory After: 1,641.914 KB
Time Before: 0.05286 seconds
Time After: 0.05323 seconds
Time Before: 0.05586 seconds
Time After: 0.05719 seconds
Time Taken: 0.00133 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.05219 seconds
Time After: 0.05743 seconds
Time Taken: 0.00524 seconds
Memory After: 2,261.703 KB
Time Before: 0.10172 seconds
Time After: 0.10190 seconds
Memory Before: 2,815.273 KB
Memory After: 2,815.789 KB
Time Before: 0.12171 seconds
Time After: 0.12299 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.12528085708618
Time Before: 0.13490 seconds
Time After: 0.13510 seconds
Memory Before: 3,540.375 KB
Memory After: 3,540.805 KB
Time Before: 0.13749 seconds
Time After: 0.13893 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=84865'
Time Before: 0.15879 seconds
Time After: 0.15911 seconds
Memory Before: 4,295.484 KB
Memory After: 4,295.727 KB
Page generated in 0.15755605697632 seconds with 9 queries, spending 0.0091009140014648 doing MySQL queries and 0.14845514297485 doing PHP things.
