Time Before: 0.00140 seconds
Time After: 0.00197 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00204 seconds
Time After: 0.00239 seconds
Time Before: 0.00257 seconds
Time After: 0.00270 seconds
Time Before: 0.00356 seconds
Time After: 0.00622 seconds
Time Taken: 0.00266 seconds
Time Before: 0.00280 seconds
Time After: 0.01091 seconds
Time Taken: 0.00811 seconds
Time Before: 0.01278 seconds
Time After: 0.01321 seconds
Time Before: 0.01605 seconds
Time After: 0.01723 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01218 seconds
Time After: 0.01748 seconds
Time Taken: 0.00530 seconds
Time Before: 0.02413 seconds
Time After: 0.02427 seconds
Time Before: 0.02605 seconds
Time After: 0.02728 seconds
Time Before: 0.03032 seconds
Time After: 0.03049 seconds
Time Before: 0.03308 seconds
Time After: 0.03459 seconds
Time Taken: 0.00151 seconds
UPDATE session SET lastactivity = 1785474795, location = '/forums/private.php?do=newpm&explain=1&u=84921' WHERE sessionhash = 'f787d15acff2abe23491441932164758'
Time Before: 0.05144 seconds
Time After: 0.05376 seconds
Time Taken: 0.00232 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
