Time Before: 0.01886 seconds
Time After: 0.02262 seconds
Time Taken: 0.00377 seconds
Time Before: 0.02272 seconds
Time After: 0.02318 seconds
Time Before: 0.02341 seconds
Time After: 0.02356 seconds
Time Before: 0.02434 seconds
Time After: 0.02710 seconds
Time Taken: 0.00276 seconds
Time Before: 0.02362 seconds
Time After: 0.03195 seconds
Time Taken: 0.00833 seconds
Time Before: 0.03970 seconds
Time After: 0.04009 seconds
Time Before: 0.04279 seconds
Time After: 0.04403 seconds
Time Before: 0.03894 seconds
Time After: 0.04423 seconds
Time Taken: 0.00530 seconds
Time Before: 0.08337 seconds
Time After: 0.08355 seconds
Time Before: 0.10252 seconds
Time After: 0.10376 seconds
End call of global.php: 0.10570812225342
Time Before: 0.11487 seconds
Time After: 0.11506 seconds
Time Before: 0.11750 seconds
Time After: 0.11896 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=8493'
Time Before: 0.13800 seconds
Time After: 0.13828 seconds
Memory Before: 4,910.797 KB
Memory After: 4,911.047 KB
Memory Used: 0.250 KB
Page generated in 0.13693904876709 seconds with 9 queries, spending 0.0083372592926025 doing MySQL queries and 0.12860178947449 doing PHP things.
