Time Before: 0.01741 seconds
Time After: 0.02359 seconds
Time Taken: 0.00618 seconds
Time Before: 0.02369 seconds
Time After: 0.02410 seconds
Time Before: 0.02430 seconds
Time After: 0.02441 seconds
Time Before: 0.02520 seconds
Time After: 0.02794 seconds
Time Taken: 0.00275 seconds
Time Before: 0.02449 seconds
Time After: 0.03241 seconds
Time Taken: 0.00792 seconds
Time Before: 0.03914 seconds
Time After: 0.03955 seconds
Time Before: 0.04200 seconds
Time After: 0.04323 seconds
Time Before: 0.03840 seconds
Time After: 0.04346 seconds
Time Taken: 0.00506 seconds
Time Before: 0.08702 seconds
Time After: 0.08721 seconds
Time Before: 0.10723 seconds
Time After: 0.10848 seconds
Time Before: 0.12234 seconds
Time After: 0.12248 seconds
Time Before: 0.12522 seconds
Time After: 0.12663 seconds
UPDATE session SET lastactivity = 1776783739, location = '/forums/private.php?do=newpm&explain=1&u=85003' WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.14812 seconds
Time After: 0.14848 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
