Time Before: 0.00161 seconds
Time After: 0.00209 seconds
Time Before: 0.00216 seconds
Time After: 0.00264 seconds
Time Before: 0.00286 seconds
Time After: 0.00303 seconds
Time Before: 0.00369 seconds
Time After: 0.00655 seconds
Time Taken: 0.00287 seconds
Time Before: 0.00307 seconds
Time After: 0.01154 seconds
Time Taken: 0.00846 seconds
Time Before: 0.01353 seconds
Time After: 0.01395 seconds
Time Before: 0.01665 seconds
Time After: 0.01787 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01279 seconds
Time After: 0.01810 seconds
Time Taken: 0.00532 seconds
Memory After: 2,261.719 KB
Time Before: 0.02410 seconds
Time After: 0.02429 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02657 seconds
Time After: 0.02807 seconds
Time Taken: 0.00150 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.03092 seconds
Time After: 0.03108 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03322 seconds
Time After: 0.03506 seconds
Time Taken: 0.00184 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=85073' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.05172 seconds
Time After: 0.05207 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
