Time Before: 0.00191 seconds
Time After: 0.00268 seconds
Time Taken: 0.00077 seconds
Time Before: 0.00275 seconds
Time After: 0.00333 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00362 seconds
Time After: 0.00386 seconds
Time Before: 0.00457 seconds
Time After: 0.00748 seconds
Time Taken: 0.00291 seconds
Time Before: 0.00394 seconds
Time After: 0.01237 seconds
Time Taken: 0.00843 seconds
Time Before: 0.01448 seconds
Time After: 0.01491 seconds
Time Before: 0.01738 seconds
Time After: 0.01860 seconds
Time Before: 0.01389 seconds
Time After: 0.01878 seconds
Time Taken: 0.00489 seconds
Time Before: 0.02586 seconds
Time After: 0.02602 seconds
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"11.25,\";s:9:\"lastcheck\";i:1788872610;}', 1)Time Before: 0.03215 seconds
Time After: 0.03287 seconds
Time Taken: 0.00073 seconds
Memory Before: 3,439.641 KB
Memory After: 3,439.891 KB
Memory Used: 0.250 KB
Time Before: 0.03582 seconds
Time After: 0.03753 seconds
Time Taken: 0.00171 seconds
Memory Before: 3,526.445 KB
Memory After: 3,527.039 KB
Time Before: 0.04130 seconds
Time After: 0.04146 seconds
Memory Before: 4,164.313 KB
Memory After: 4,164.742 KB
Time Before: 0.04379 seconds
Time After: 0.04522 seconds
Memory Before: 4,446.055 KB
Memory After: 4,447.742 KB
UPDATE session SET lastactivity = 1788872610, location = '/forums/private.php?do=newpm&explain=1&u=85307' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05840 seconds
Time After: 0.05872 seconds
Memory Before: 4,919.750 KB
Memory After: 4,919.977 KB
