Time Before: 0.01657 seconds
Time After: 0.02177 seconds
Time Taken: 0.00520 seconds
Time Before: 0.02188 seconds
Time After: 0.02237 seconds
Time Before: 0.02261 seconds
Time After: 0.02274 seconds
Time Before: 0.02362 seconds
Time After: 0.02704 seconds
Time Taken: 0.00341 seconds
Time Before: 0.02282 seconds
Time After: 0.03105 seconds
Time Taken: 0.00823 seconds
Time Before: 0.04016 seconds
Time After: 0.04059 seconds
Time Before: 0.04309 seconds
Time After: 0.04441 seconds
Time Taken: 0.00132 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.03944 seconds
Time After: 0.04464 seconds
Memory After: 2,261.719 KB
Time Before: 0.06570 seconds
Time After: 0.06583 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.07833 seconds
Time After: 0.07960 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.08657 seconds
Time After: 0.08674 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.08912 seconds
Time After: 0.09059 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=85327' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.10998 seconds
Time After: 0.11024 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
