Time Before: 0.00150 seconds
Time After: 0.00194 seconds
Time Before: 0.00200 seconds
Time After: 0.00243 seconds
Time Before: 0.00271 seconds
Time After: 0.00284 seconds
Time Before: 0.00363 seconds
Time After: 0.00594 seconds
Time Taken: 0.00231 seconds
Time Before: 0.00289 seconds
Time After: 0.00930 seconds
Time Taken: 0.00641 seconds
Time Before: 0.01108 seconds
Time After: 0.01153 seconds
Time Before: 0.01457 seconds
Time After: 0.01585 seconds
Time Before: 0.01051 seconds
Time After: 0.01607 seconds
Time Taken: 0.00556 seconds
Time Before: 0.02227 seconds
Time After: 0.02240 seconds
Time Before: 0.02428 seconds
Time After: 0.02550 seconds
End call of global.php: 0.027162790298462
Time Before: 0.02868 seconds
Time After: 0.02884 seconds
Time Before: 0.03181 seconds
Time After: 0.03326 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=85337'
Time Before: 0.05154 seconds
Time After: 0.05179 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.050118923187256 seconds with 9 queries, spending 0.0078046321868896 doing MySQL queries and 0.042314291000366 doing PHP things.
