Time Before: 0.00279 seconds
Time After: 0.00376 seconds
Time Taken: 0.00098 seconds
Time Before: 0.00387 seconds
Time After: 0.00425 seconds
Time Before: 0.00449 seconds
Time After: 0.00463 seconds
Time Before: 0.00591 seconds
Time After: 0.00818 seconds
Time Taken: 0.00227 seconds
Time Before: 0.00471 seconds
Time After: 0.01394 seconds
Time Taken: 0.00923 seconds
Time Before: 0.01743 seconds
Time After: 0.01781 seconds
Time Before: 0.02046 seconds
Time After: 0.02164 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01687 seconds
Time After: 0.02183 seconds
Time Taken: 0.00496 seconds
Time Before: 0.03605 seconds
Time After: 0.03618 seconds
Time Before: 0.05827 seconds
Time After: 0.05953 seconds
End call of global.php: 0.062136888504028
Time Before: 0.06455 seconds
Time After: 0.06474 seconds
Time Before: 0.06778 seconds
Time After: 0.06998 seconds
Time Taken: 0.00220 seconds
SET lastactivity = 1788981297, location = '/forums/private.php?do=newpm&explain=1&u=85627', badlocation = 1
Time Before: 0.08549 seconds
Time After: 0.08571 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.084564924240112 seconds with 9 queries, spending 0.0083353519439697 doing MySQL queries and 0.076229572296143 doing PHP things.
