Time Before: 0.00136 seconds
Time After: 0.00185 seconds
Time Before: 0.00192 seconds
Time After: 0.00241 seconds
Time Before: 0.00269 seconds
Time After: 0.00284 seconds
Time Before: 0.00383 seconds
Time After: 0.00749 seconds
Time Taken: 0.00366 seconds
Time Before: 0.00289 seconds
Time After: 0.01090 seconds
Time Taken: 0.00800 seconds
Time Before: 0.01305 seconds
Time After: 0.01349 seconds
Time Before: 0.01611 seconds
Time After: 0.01735 seconds
Time Before: 0.01218 seconds
Time After: 0.01756 seconds
Time Taken: 0.00538 seconds
Time Before: 0.02396 seconds
Time After: 0.02430 seconds
Time Before: 0.02621 seconds
Time After: 0.02791 seconds
Time Taken: 0.00170 seconds
End call of global.php: 0.030220985412598
Time Before: 0.03159 seconds
Time After: 0.03174 seconds
Time Before: 0.03397 seconds
Time After: 0.03554 seconds
Time Taken: 0.00157 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=85629'
Time Before: 0.04964 seconds
Time After: 0.05003 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.048282861709595 seconds with 9 queries, spending 0.010136127471924 doing MySQL queries and 0.038146734237671 doing PHP things.
