Time Before: 0.00143 seconds
Time After: 0.00206 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00218 seconds
Time After: 0.00264 seconds
Time Before: 0.00326 seconds
Time After: 0.00372 seconds
Time Before: 0.00465 seconds
Time After: 0.00730 seconds
Time Taken: 0.00266 seconds
Time Before: 0.00378 seconds
Time After: 0.01068 seconds
Time Taken: 0.00690 seconds
Time Before: 0.01252 seconds
Time After: 0.01294 seconds
Time Before: 0.01471 seconds
Time After: 0.01598 seconds
Time Before: 0.01191 seconds
Time After: 0.01615 seconds
Time Taken: 0.00424 seconds
Time Before: 0.02269 seconds
Time After: 0.02282 seconds
Time Before: 0.02533 seconds
Time After: 0.02665 seconds
Time Taken: 0.00132 seconds
End call of global.php: 0.028321981430054
Time Before: 0.02991 seconds
Time After: 0.03008 seconds
Time Before: 0.03212 seconds
Time After: 0.03417 seconds
Time Taken: 0.00205 seconds
SET lastactivity = 1788947549, location = '/forums/private.php?do=newpm&explain=1&u=85747'
Time Before: 0.04652 seconds
Time After: 0.04717 seconds
Time Taken: 0.00065 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.045575141906738 seconds with 9 queries, spending 0.0095810890197754 doing MySQL queries and 0.035994052886963 doing PHP things.
