Time Before: 0.00183 seconds
Time After: 0.00229 seconds
Time Before: 0.00236 seconds
Time After: 0.00284 seconds
Time Before: 0.00306 seconds
Time After: 0.00318 seconds
Time Before: 0.00385 seconds
Time After: 0.00660 seconds
Time Taken: 0.00275 seconds
Time Before: 0.00323 seconds
Time After: 0.01002 seconds
Time Taken: 0.00679 seconds
Time Before: 0.01185 seconds
Time After: 0.01223 seconds
Time Before: 0.01483 seconds
Time After: 0.01758 seconds
Time Before: 0.01131 seconds
Time After: 0.01777 seconds
Time Taken: 0.00646 seconds
Time Before: 0.02342 seconds
Time After: 0.02376 seconds
Time Before: 0.02578 seconds
Time After: 0.02705 seconds
End call of global.php: 0.028794050216675
Time Before: 0.03000 seconds
Time After: 0.03014 seconds
Time Before: 0.03238 seconds
Time After: 0.03390 seconds
Time Taken: 0.00152 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=85750'
Time Before: 0.04813 seconds
Time After: 0.04851 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.047197103500366 seconds with 9 queries, spending 0.010122299194336 doing MySQL queries and 0.03707480430603 doing PHP things.
