Time Before: 0.00156 seconds
Time After: 0.00208 seconds
Time Before: 0.00215 seconds
Time After: 0.00273 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00298 seconds
Time After: 0.00315 seconds
Time Before: 0.00385 seconds
Time After: 0.00600 seconds
Time Taken: 0.00215 seconds
Time Before: 0.00321 seconds
Time After: 0.00938 seconds
Time Taken: 0.00617 seconds
Time Before: 0.01107 seconds
Time After: 0.01127 seconds
Time Before: 0.01370 seconds
Time After: 0.01487 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01048 seconds
Time After: 0.01504 seconds
Time Taken: 0.00455 seconds
Time Before: 0.01986 seconds
Time After: 0.02004 seconds
Time Before: 0.02225 seconds
Time After: 0.02353 seconds
End call of global.php: 0.025150060653687
Time Before: 0.02648 seconds
Time After: 0.02663 seconds
Time Before: 0.02877 seconds
Time After: 0.03024 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=85765', badlocation = 1
Time Before: 0.04720 seconds
Time After: 0.04748 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.045922040939331 seconds with 9 queries, spending 0.0076298713684082 doing MySQL queries and 0.038292169570923 doing PHP things.
