Time Before: 0.00167 seconds
Time After: 0.00222 seconds
Time Taken: 0.00055 seconds
Memory Before: 1,157.773 KB
Memory After: 1,182.891 KB
Time Before: 0.00232 seconds
Time After: 0.00271 seconds
Memory Before: 1,182.828 KB
Memory After: 1,183.836 KB
Time Before: 0.00297 seconds
Time After: 0.00310 seconds
Memory Before: 1,184.422 KB
Memory After: 1,184.945 KB
Time Before: 0.00399 seconds
Time After: 0.00639 seconds
Time Taken: 0.00240 seconds
Memory Before: 1,187.547 KB
Memory After: 1,188.469 KB
Time Before: 0.00318 seconds
Time After: 0.01109 seconds
Time Taken: 0.00791 seconds
Memory Before: 1,184.164 KB
Memory After: 2,265.219 KB
Memory Used: 1,081.055 KB
Time Before: 0.01289 seconds
Time After: 0.01334 seconds
Memory Before: 2,758.023 KB
Memory After: 2,758.641 KB
Time Before: 0.01691 seconds
Time After: 0.01829 seconds
Time Taken: 0.00137 seconds
Memory Before: 2,770.195 KB
Memory After: 2,770.055 KB
Time Before: 0.01226 seconds
Time After: 0.01856 seconds
Time Taken: 0.00629 seconds
Memory Before: 2,750.172 KB
Memory After: 2,883.414 KB
Memory Used: 133.242 KB
Time Before: 0.02393 seconds
Time After: 0.02405 seconds
Memory Before: 3,436.539 KB
Memory After: 3,437.055 KB
Time Before: 0.02607 seconds
Time After: 0.02734 seconds
Memory Before: 3,524.336 KB
Memory After: 3,524.930 KB
Time Before: 0.03055 seconds
Time After: 0.03067 seconds
Memory Before: 4,162.242 KB
Memory After: 4,162.672 KB
Time Before: 0.03281 seconds
Time After: 0.03426 seconds
Memory Before: 4,443.805 KB
Memory After: 4,445.492 KB
UPDATE session SET lastactivity = 1788951907, location = '/forums/private.php?do=newpm&explain=1&u=85851', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04823 seconds
Time After: 0.04860 seconds
Memory Before: 4,922.375 KB
Memory After: 4,922.586 KB
