Time Before: 0.02048 seconds
Time After: 0.03075 seconds
Time Taken: 0.01026 seconds
Time Before: 0.03085 seconds
Time After: 0.03121 seconds
Time Before: 0.03145 seconds
Time After: 0.03163 seconds
Time Before: 0.03247 seconds
Time After: 0.03450 seconds
Time Taken: 0.00203 seconds
Time Before: 0.03170 seconds
Time After: 0.03863 seconds
Time Taken: 0.00693 seconds
Time Before: 0.05015 seconds
Time After: 0.05135 seconds
Time Before: 0.05406 seconds
Time After: 0.05526 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.04944 seconds
Time After: 0.05550 seconds
Time Taken: 0.00606 seconds
Memory After: 2,261.719 KB
Time Before: 0.07636 seconds
Time After: 0.07649 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.10167 seconds
Time After: 0.10294 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.10599207878113
Time Before: 0.11470 seconds
Time After: 0.11495 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.11772 seconds
Time After: 0.11916 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=85922', badlocation = 1
Time Before: 0.13929 seconds
Time After: 0.13955 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
Page generated in 0.13827800750732 seconds with 9 queries, spending 0.0083389282226562 doing MySQL queries and 0.12993907928467 doing PHP things.
