Time Before: 0.00140 seconds
Time After: 0.00191 seconds
Time Before: 0.00199 seconds
Time After: 0.00243 seconds
Time Before: 0.00264 seconds
Time After: 0.00277 seconds
Time Before: 0.00341 seconds
Time After: 0.00615 seconds
Time Taken: 0.00274 seconds
Time Before: 0.00282 seconds
Time After: 0.00955 seconds
Time Taken: 0.00674 seconds
Time Before: 0.01143 seconds
Time After: 0.01164 seconds
Time Before: 0.01401 seconds
Time After: 0.01521 seconds
Time Before: 0.01083 seconds
Time After: 0.01538 seconds
Time Taken: 0.00455 seconds
Time Before: 0.02046 seconds
Time After: 0.02061 seconds
Time Before: 0.02241 seconds
Time After: 0.02363 seconds
End call of global.php: 0.025264024734497
Time Before: 0.02645 seconds
Time After: 0.02662 seconds
Time Before: 0.02856 seconds
Time After: 0.03000 seconds
SET lastactivity = 1776973538, location = '/forums/private.php?do=newpm&explain=1&u=85950', badlocation = 1
WHERE sessionhash = 'df28b2ca2ba03bfc49481a2edca83948'
Time Before: 0.04232 seconds
Time After: 0.04271 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.041407108306885 seconds with 9 queries, spending 0.0081124305725098 doing MySQL queries and 0.033294677734375 doing PHP things.
