Time Before: 0.02564 seconds
Time After: 0.03308 seconds
Time Taken: 0.00744 seconds
Time Before: 0.03319 seconds
Time After: 0.03362 seconds
Time Before: 0.03388 seconds
Time After: 0.03403 seconds
Time Before: 0.03492 seconds
Time After: 0.03776 seconds
Time Taken: 0.00284 seconds
Time Before: 0.03411 seconds
Time After: 0.04166 seconds
Time Taken: 0.00755 seconds
Time Before: 0.05326 seconds
Time After: 0.05369 seconds
Time Before: 0.05520 seconds
Time After: 0.05646 seconds
Time Before: 0.05245 seconds
Time After: 0.05665 seconds
Time Taken: 0.00419 seconds
Time Before: 0.10046 seconds
Time After: 0.10061 seconds
Time Before: 0.11294 seconds
Time After: 0.11422 seconds
Time Before: 0.12282 seconds
Time After: 0.12301 seconds
Time Before: 0.12610 seconds
Time After: 0.12757 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=85962' WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.15061 seconds
Time After: 0.15089 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
