Time Before: 0.00777 seconds
Time After: 0.00945 seconds
Time Taken: 0.00169 seconds
Time Before: 0.00955 seconds
Time After: 0.00999 seconds
Time Before: 0.01024 seconds
Time After: 0.01038 seconds
Time Before: 0.01125 seconds
Time After: 0.01351 seconds
Time Taken: 0.00225 seconds
Time Before: 0.01044 seconds
Time After: 0.01802 seconds
Time Taken: 0.00758 seconds
Time Before: 0.02177 seconds
Time After: 0.02232 seconds
Time Taken: 0.00054 seconds
Time Before: 0.02569 seconds
Time After: 0.02694 seconds
Time Before: 0.02100 seconds
Time After: 0.02715 seconds
Time Taken: 0.00615 seconds
Time Before: 0.04157 seconds
Time After: 0.04170 seconds
Time Before: 0.04890 seconds
Time After: 0.05015 seconds
End call of global.php: 0.052614212036133
Time Before: 0.05807 seconds
Time After: 0.05823 seconds
Time Before: 0.06076 seconds
Time After: 0.06220 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=86075', badlocation = 1
Time Before: 0.07998 seconds
Time After: 0.08033 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.078767061233521 seconds with 9 queries, spending 0.0079371929168701 doing MySQL queries and 0.07082986831665 doing PHP things.
