Time Before: 0.00498 seconds
Time After: 0.00633 seconds
Time Taken: 0.00135 seconds
Time Before: 0.00643 seconds
Time After: 0.00689 seconds
Time Before: 0.00714 seconds
Time After: 0.00727 seconds
Time Before: 0.00806 seconds
Time After: 0.01040 seconds
Time Taken: 0.00233 seconds
Time Before: 0.00732 seconds
Time After: 0.01373 seconds
Time Taken: 0.00641 seconds
Time Before: 0.01598 seconds
Time After: 0.01638 seconds
Time Before: 0.01780 seconds
Time After: 0.01914 seconds
Time Taken: 0.00134 seconds
Time Before: 0.01537 seconds
Time After: 0.01938 seconds
Time Taken: 0.00401 seconds
Time Before: 0.02767 seconds
Time After: 0.02788 seconds
Time Before: 0.03000 seconds
Time After: 0.03146 seconds
Time Before: 0.03495 seconds
Time After: 0.03515 seconds
Time Before: 0.03736 seconds
Time After: 0.03883 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=86089', badlocation = 1 WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.05687 seconds
Time After: 0.05713 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
