Time Before: 0.00187 seconds
Time After: 0.00256 seconds
Time Taken: 0.00069 seconds
Time Before: 0.00263 seconds
Time After: 0.00383 seconds
Time Before: 0.00412 seconds
Time After: 0.00425 seconds
Time Before: 0.00489 seconds
Time After: 0.00738 seconds
Time Taken: 0.00249 seconds
Time Before: 0.00430 seconds
Time After: 0.01087 seconds
Time Taken: 0.00657 seconds
Time Before: 0.01327 seconds
Time After: 0.01366 seconds
Time Before: 0.01625 seconds
Time After: 0.01881 seconds
Time Taken: 0.00256 seconds
Time Before: 0.01244 seconds
Time After: 0.01901 seconds
Time Before: 0.02517 seconds
Time After: 0.02541 seconds
Time Before: 0.02878 seconds
Time After: 0.03038 seconds
Time Taken: 0.00160 seconds
End call of global.php: 0.033344030380249
Time Before: 0.03476 seconds
Time After: 0.03495 seconds
Time Before: 0.03791 seconds
Time After: 0.03961 seconds
Time Taken: 0.00170 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=86216'
Time Before: 0.05427 seconds
Time After: 0.05465 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.053324937820435 seconds with 9 queries, spending 0.010878801345825 doing MySQL queries and 0.042446136474609 doing PHP things.
