Time Before: 0.00244 seconds
Time After: 0.00291 seconds
Time Before: 0.00298 seconds
Time After: 0.00338 seconds
Time Before: 0.00361 seconds
Time After: 0.00375 seconds
Time Before: 0.00452 seconds
Time After: 0.00736 seconds
Time Taken: 0.00284 seconds
Time Before: 0.00383 seconds
Time After: 0.01129 seconds
Time Taken: 0.00747 seconds
Time Before: 0.01328 seconds
Time After: 0.01372 seconds
Time Before: 0.01631 seconds
Time After: 0.01759 seconds
Time Before: 0.01256 seconds
Time After: 0.01786 seconds
Time Taken: 0.00530 seconds
Time Before: 0.02484 seconds
Time After: 0.02497 seconds
Time Before: 0.02700 seconds
Time After: 0.02839 seconds
Time Taken: 0.00139 seconds
End call of global.php: 0.030182123184204
Time Before: 0.03136 seconds
Time After: 0.03150 seconds
Time Before: 0.03351 seconds
Time After: 0.03491 seconds
SET lastactivity = 1776610937, location = '/forums/private.php?do=newpm&explain=1&u=86303'
Time Before: 0.04735 seconds
Time After: 0.04767 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.046457052230835 seconds with 9 queries, spending 0.0084764957427979 doing MySQL queries and 0.037980556488037 doing PHP things.
