Time Before: 0.00192 seconds
Time After: 0.00250 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00260 seconds
Time After: 0.00321 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00350 seconds
Time After: 0.00374 seconds
Time Before: 0.00450 seconds
Time After: 0.00739 seconds
Time Taken: 0.00289 seconds
Time Before: 0.00380 seconds
Time After: 0.01138 seconds
Time Taken: 0.00758 seconds
Time Before: 0.01315 seconds
Time After: 0.01359 seconds
Time Before: 0.01506 seconds
Time After: 0.01629 seconds
Time Before: 0.01252 seconds
Time After: 0.01648 seconds
Time Taken: 0.00396 seconds
Time Before: 0.02212 seconds
Time After: 0.02225 seconds
Time Before: 0.02401 seconds
Time After: 0.02523 seconds
End call of global.php: 0.026916980743408
Time Before: 0.02821 seconds
Time After: 0.02834 seconds
Time Before: 0.03043 seconds
Time After: 0.03186 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=86402'
Time Before: 0.04483 seconds
Time After: 0.04521 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.043931007385254 seconds with 9 queries, spending 0.0087127685546875 doing MySQL queries and 0.035218238830566 doing PHP things.
