Time Before: 0.00354 seconds
Time After: 0.00486 seconds
Time Taken: 0.00132 seconds
Time Before: 0.00493 seconds
Time After: 0.00545 seconds
Time Before: 0.00571 seconds
Time After: 0.00586 seconds
Time Before: 0.00659 seconds
Time After: 0.00962 seconds
Time Taken: 0.00302 seconds
Time Before: 0.00594 seconds
Time After: 0.01415 seconds
Time Taken: 0.00821 seconds
Time Before: 0.01748 seconds
Time After: 0.01784 seconds
Time Before: 0.01974 seconds
Time After: 0.02219 seconds
Time Taken: 0.00245 seconds
Time Before: 0.01682 seconds
Time After: 0.02242 seconds
Time Taken: 0.00561 seconds
Time Before: 0.03232 seconds
Time After: 0.03246 seconds
Time Before: 0.03700 seconds
Time After: 0.03829 seconds
End call of global.php: 0.040897846221924
Time Before: 0.04271 seconds
Time After: 0.04319 seconds
Time Before: 0.04557 seconds
Time After: 0.04729 seconds
Time Taken: 0.00172 seconds
SET lastactivity = 1777014711, location = '/forums/private.php?do=newpm&explain=1&u=86412', badlocation = 1
WHERE sessionhash = '87651ca345a619a09949038b7f47c9ec'
Time Before: 0.06345 seconds
Time After: 0.06369 seconds
Memory Before: 4,289.406 KB
Memory After: 4,289.617 KB
Page generated in 0.06252384185791 seconds with 9 queries, spending 0.010374546051025 doing MySQL queries and 0.052149295806885 doing PHP things.
