Time Before: 0.00129 seconds
Time After: 0.00173 seconds
Time Before: 0.00182 seconds
Time After: 0.00224 seconds
Time Before: 0.00249 seconds
Time After: 0.00264 seconds
Time Before: 0.00333 seconds
Time After: 0.00556 seconds
Time Taken: 0.00224 seconds
Time Before: 0.00269 seconds
Time After: 0.00900 seconds
Time Taken: 0.00631 seconds
Time Before: 0.01116 seconds
Time After: 0.01155 seconds
Time Before: 0.01442 seconds
Time After: 0.01564 seconds
Time Before: 0.01047 seconds
Time After: 0.01589 seconds
Time Taken: 0.00542 seconds
Time Before: 0.02312 seconds
Time After: 0.02327 seconds
Time Before: 0.02533 seconds
Time After: 0.02653 seconds
End call of global.php: 0.028255939483643
Time Before: 0.02953 seconds
Time After: 0.02969 seconds
Time Before: 0.03262 seconds
Time After: 0.03403 seconds
Time Taken: 0.00140 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=86479'
Time Before: 0.05036 seconds
Time After: 0.05062 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.049176931381226 seconds with 9 queries, spending 0.0075960159301758 doing MySQL queries and 0.04158091545105 doing PHP things.
