Time Before: 0.00134 seconds
Time After: 0.00177 seconds
Memory Before: 533.906 KB
Memory After: 559.023 KB
Time Before: 0.00185 seconds
Time After: 0.00222 seconds
Memory Before: 558.961 KB
Memory After: 559.969 KB
Time Before: 0.00240 seconds
Time After: 0.00251 seconds
Memory Before: 560.523 KB
Memory After: 561.047 KB
Time Before: 0.00321 seconds
Time After: 0.00571 seconds
Time Taken: 0.00250 seconds
Memory Before: 563.648 KB
Memory After: 564.570 KB
Time Before: 0.00256 seconds
Time After: 0.00910 seconds
Time Taken: 0.00654 seconds
Memory Before: 560.297 KB
Memory After: 1,641.297 KB
Memory Used: 1,081.000 KB
Time Before: 0.01117 seconds
Time After: 0.01163 seconds
Memory Before: 2,136.141 KB
Memory After: 2,136.758 KB
Time Before: 0.01509 seconds
Time After: 0.01632 seconds
Memory Before: 2,148.320 KB
Memory After: 2,148.180 KB
Time Before: 0.01044 seconds
Time After: 0.01650 seconds
Time Taken: 0.00606 seconds
Memory Before: 2,128.320 KB
Memory After: 2,261.203 KB
Time Before: 0.02168 seconds
Time After: 0.02203 seconds
Memory Before: 2,814.781 KB
Memory After: 2,815.297 KB
Time Before: 0.02448 seconds
Time After: 0.02571 seconds
Memory Before: 2,903.117 KB
Memory After: 2,903.711 KB
End call of global.php: 0.027431964874268
Time Before: 0.02877 seconds
Time After: 0.02899 seconds
Memory Before: 3,539.836 KB
Memory After: 3,540.266 KB
Time Before: 0.03134 seconds
Time After: 0.03291 seconds
Time Taken: 0.00157 seconds
Memory Before: 3,821.367 KB
Memory After: 3,823.055 KB
SET lastactivity = 1788880078, location = '/forums/private.php?do=newpm&explain=1&u=8648'
Time Before: 0.04523 seconds
Time After: 0.04571 seconds
Memory Before: 4,295.195 KB
Memory After: 4,295.414 KB
Page generated in 0.044339895248413 seconds with 9 queries, spending 0.0085163116455078 doing MySQL queries and 0.035823583602905 doing PHP things.
