Time Before: 0.02337 seconds
Time After: 0.02991 seconds
Time Taken: 0.00653 seconds
Time Before: 0.03001 seconds
Time After: 0.03050 seconds
Time Before: 0.03075 seconds
Time After: 0.03089 seconds
Time Before: 0.03177 seconds
Time After: 0.03437 seconds
Time Taken: 0.00260 seconds
Time Before: 0.03096 seconds
Time After: 0.03841 seconds
Time Taken: 0.00744 seconds
Time Before: 0.04632 seconds
Time After: 0.04667 seconds
Time Before: 0.04928 seconds
Time After: 0.05188 seconds
Time Taken: 0.00259 seconds
Time Before: 0.04562 seconds
Time After: 0.05215 seconds
Time Before: 0.08391 seconds
Time After: 0.08407 seconds
Time Before: 0.10271 seconds
Time After: 0.10398 seconds
End call of global.php: 0.10582709312439
Time Before: 0.11444 seconds
Time After: 0.11461 seconds
Time Before: 0.11776 seconds
Time After: 0.11921 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=86788'
Time Before: 0.14351 seconds
Time After: 0.14385 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.1419620513916 seconds with 9 queries, spending 0.0095441341400146 doing MySQL queries and 0.13241791725159 doing PHP things.
