Time Before: 0.00199 seconds
Time After: 0.00264 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00271 seconds
Time After: 0.00310 seconds
Time Before: 0.00331 seconds
Time After: 0.00346 seconds
Time Before: 0.00440 seconds
Time After: 0.00696 seconds
Time Taken: 0.00256 seconds
Time Before: 0.00353 seconds
Time After: 0.01257 seconds
Time Taken: 0.00904 seconds
Time Before: 0.01487 seconds
Time After: 0.01528 seconds
Time Before: 0.01850 seconds
Time After: 0.01978 seconds
Time Before: 0.01411 seconds
Time After: 0.02003 seconds
Time Taken: 0.00591 seconds
Time Before: 0.02783 seconds
Time After: 0.02797 seconds
Time Before: 0.03026 seconds
Time After: 0.03150 seconds
Time Before: 0.03690 seconds
Time After: 0.03720 seconds
Time Before: 0.04035 seconds
Time After: 0.04242 seconds
Time Taken: 0.00207 seconds
UPDATE session SET lastactivity = 1785310832, location = '/forums/private.php?do=newpm&explain=1&u=8680', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.05490 seconds
Time After: 0.05519 seconds
Memory Before: 4,911.445 KB
Memory After: 4,911.656 KB
