Time Before: 0.00245 seconds
Time After: 0.00320 seconds
Time Taken: 0.00075 seconds
Time Before: 0.00330 seconds
Time After: 0.00375 seconds
Time Before: 0.00401 seconds
Time After: 0.00412 seconds
Time Before: 0.00486 seconds
Time After: 0.00737 seconds
Time Taken: 0.00251 seconds
Time Before: 0.00417 seconds
Time After: 0.01076 seconds
Time Taken: 0.00658 seconds
Time Before: 0.01283 seconds
Time After: 0.01304 seconds
Time Before: 0.01614 seconds
Time After: 0.01736 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01211 seconds
Time After: 0.01754 seconds
Time Taken: 0.00543 seconds
Memory After: 2,261.836 KB
Time Before: 0.02375 seconds
Time After: 0.02391 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.02564 seconds
Time After: 0.02700 seconds
Time Taken: 0.00136 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.03038 seconds
Time After: 0.03059 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.03302 seconds
Time After: 0.03448 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1788906255, location = '/forums/private.php?do=newpm&explain=1&u=86837', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04984 seconds
Time After: 0.05029 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
