Time Before: 0.00283 seconds
Time After: 0.00361 seconds
Time Taken: 0.00077 seconds
Time Before: 0.00368 seconds
Time After: 0.00416 seconds
Time Before: 0.00443 seconds
Time After: 0.00459 seconds
Time Before: 0.00526 seconds
Time After: 0.00806 seconds
Time Taken: 0.00280 seconds
Time Before: 0.00465 seconds
Time After: 0.01146 seconds
Time Taken: 0.00681 seconds
Time Before: 0.01329 seconds
Time After: 0.01371 seconds
Time Before: 0.01622 seconds
Time After: 0.01745 seconds
Time Before: 0.01275 seconds
Time After: 0.01763 seconds
Time Taken: 0.00488 seconds
Time Before: 0.02260 seconds
Time After: 0.02277 seconds
Time Before: 0.02472 seconds
Time After: 0.02594 seconds
Time Before: 0.02927 seconds
Time After: 0.02949 seconds
Time Before: 0.03154 seconds
Time After: 0.03294 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=8686', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.04513 seconds
Time After: 0.04548 seconds
Memory Before: 4,911.086 KB
Memory After: 4,911.313 KB
