Time Before: 0.00145 seconds
Time After: 0.00191 seconds
Time Before: 0.00199 seconds
Time After: 0.00267 seconds
Time Taken: 0.00069 seconds
Time Before: 0.00292 seconds
Time After: 0.00306 seconds
Time Before: 0.00379 seconds
Time After: 0.00681 seconds
Time Taken: 0.00302 seconds
Time Before: 0.00311 seconds
Time After: 0.01046 seconds
Time Taken: 0.00735 seconds
Time Before: 0.01272 seconds
Time After: 0.01313 seconds
Time Before: 0.01580 seconds
Time After: 0.01711 seconds
Time Taken: 0.00131 seconds
Time Before: 0.01178 seconds
Time After: 0.01732 seconds
Time Taken: 0.00554 seconds
Time Before: 0.02355 seconds
Time After: 0.02369 seconds
Time Before: 0.02561 seconds
Time After: 0.02686 seconds
Time Before: 0.03024 seconds
Time After: 0.03038 seconds
Time Before: 0.03269 seconds
Time After: 0.03412 seconds
UPDATE session SET lastactivity = 1776750747, location = '/forums/private.php?do=newpm&explain=1&u=87182', badlocation = 1 WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.04689 seconds
Time After: 0.04720 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
