Time Before: 0.00157 seconds
Time After: 0.00217 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00224 seconds
Time After: 0.00318 seconds
Time Taken: 0.00094 seconds
Time Before: 0.00340 seconds
Time After: 0.00353 seconds
Time Before: 0.00419 seconds
Time After: 0.00677 seconds
Time Taken: 0.00258 seconds
Time Before: 0.00358 seconds
Time After: 0.01012 seconds
Time Taken: 0.00654 seconds
Time Before: 0.01180 seconds
Time After: 0.01206 seconds
Time Before: 0.01381 seconds
Time After: 0.01643 seconds
Time Taken: 0.00261 seconds
Time Before: 0.01125 seconds
Time After: 0.01660 seconds
Time Taken: 0.00535 seconds
Time Before: 0.02166 seconds
Time After: 0.02180 seconds
Time Before: 0.02353 seconds
Time After: 0.02477 seconds
End call of global.php: 0.026401042938232
Time Before: 0.02769 seconds
Time After: 0.02785 seconds
Time Before: 0.02991 seconds
Time After: 0.03138 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=87329', badlocation = 1
WHERE sessionhash = '4737b6efab9faed20c53299b3b330814'
Time Before: 0.04374 seconds
Time After: 0.04406 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.042850017547607 seconds with 9 queries, spending 0.0098490715026855 doing MySQL queries and 0.033000946044922 doing PHP things.
