Time Before: 0.00165 seconds
Time After: 0.00213 seconds
Time Before: 0.00220 seconds
Time After: 0.00262 seconds
Time Before: 0.00289 seconds
Time After: 0.00306 seconds
Time Before: 0.00387 seconds
Time After: 0.00620 seconds
Time Taken: 0.00233 seconds
Time Before: 0.00314 seconds
Time After: 0.01112 seconds
Time Taken: 0.00798 seconds
Time Before: 0.01353 seconds
Time After: 0.01397 seconds
Time Before: 0.01533 seconds
Time After: 0.01658 seconds
Time Before: 0.01282 seconds
Time After: 0.01682 seconds
Time Taken: 0.00400 seconds
Time Before: 0.02411 seconds
Time After: 0.02425 seconds
Time Before: 0.02660 seconds
Time After: 0.02822 seconds
Time Taken: 0.00162 seconds
Time Before: 0.03108 seconds
Time After: 0.03121 seconds
Time Before: 0.03315 seconds
Time After: 0.03498 seconds
Time Taken: 0.00182 seconds
UPDATE session SET lastactivity = 1789147517, location = '/forums/private.php?do=newpm&explain=1&u=87506', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.04982 seconds
Time After: 0.05009 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
