Time Before: 0.00143 seconds
Time After: 0.00192 seconds
Time Before: 0.00199 seconds
Time After: 0.00251 seconds
Time Before: 0.00275 seconds
Time After: 0.00291 seconds
Time Before: 0.00361 seconds
Time After: 0.00660 seconds
Time Taken: 0.00298 seconds
Time Before: 0.00296 seconds
Time After: 0.01002 seconds
Time Taken: 0.00706 seconds
Time Before: 0.01189 seconds
Time After: 0.01237 seconds
Time Before: 0.01380 seconds
Time After: 0.01508 seconds
Time Before: 0.01125 seconds
Time After: 0.01525 seconds
Time Taken: 0.00401 seconds
Time Before: 0.02013 seconds
Time After: 0.02028 seconds
Time Before: 0.02210 seconds
Time After: 0.02333 seconds
End call of global.php: 0.024940013885498
Time Before: 0.02621 seconds
Time After: 0.02643 seconds
Time Before: 0.02857 seconds
Time After: 0.03000 seconds
SET lastactivity = 1773274217, location = '/forums/private.php?do=newpm&explain=1&u=87594'
WHERE sessionhash = '4737b6efab9faed20c53299b3b330814'
Time Before: 0.04280 seconds
Time After: 0.04318 seconds
Memory Before: 4,911.945 KB
Memory After: 4,912.172 KB
Page generated in 0.041921138763428 seconds with 9 queries, spending 0.0088469982147217 doing MySQL queries and 0.033074140548706 doing PHP things.
