Time Before: 0.03503 seconds
Time After: 0.04201 seconds
Time Taken: 0.00697 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.04211 seconds
Time After: 0.04245 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.04265 seconds
Time After: 0.04283 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.04361 seconds
Time After: 0.04632 seconds
Time Taken: 0.00271 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.04289 seconds
Time After: 0.05055 seconds
Time Taken: 0.00766 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.05874 seconds
Time After: 0.05915 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.06163 seconds
Time After: 0.06281 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.05802 seconds
Time After: 0.06301 seconds
Time Taken: 0.00499 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.10943 seconds
Time After: 0.10962 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.18229 seconds
Time After: 0.18354 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
End call of global.php: 0.18575096130371
Time Before: 0.22040 seconds
Time After: 0.22058 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.22598 seconds
Time After: 0.22748 seconds
Time Taken: 0.00150 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=87700'
WHERE sessionhash = '600503b925d08d481e162d46884ab830'
Time Before: 0.25538 seconds
Time After: 0.25572 seconds
Memory Before: 5,997.453 KB
Memory After: 5,997.695 KB
Page generated in 0.25440788269043 seconds with 9 queries, spending 0.008272647857666 doing MySQL queries and 0.24613523483276 doing PHP things.
