Time Before: 0.00248 seconds
Time After: 0.00358 seconds
Time Taken: 0.00111 seconds
Time Before: 0.00368 seconds
Time After: 0.00414 seconds
Time Before: 0.00437 seconds
Time After: 0.00449 seconds
Time Before: 0.00539 seconds
Time After: 0.00807 seconds
Time Taken: 0.00268 seconds
Time Before: 0.00456 seconds
Time After: 0.01295 seconds
Time Taken: 0.00839 seconds
Time Before: 0.01590 seconds
Time After: 0.01635 seconds
Time Before: 0.01970 seconds
Time After: 0.02136 seconds
Time Taken: 0.00166 seconds
Time Before: 0.01516 seconds
Time After: 0.02160 seconds
Time Taken: 0.00644 seconds
Time Before: 0.02983 seconds
Time After: 0.02999 seconds
Time Before: 0.03263 seconds
Time After: 0.03390 seconds
Time Before: 0.03730 seconds
Time After: 0.03745 seconds
Time Before: 0.03960 seconds
Time After: 0.04104 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=87717' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.05397 seconds
Time After: 0.05440 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
