Time Before: 0.03544 seconds
Time After: 0.04355 seconds
Time Taken: 0.00811 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.04364 seconds
Time After: 0.04408 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.04431 seconds
Time After: 0.04452 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.04535 seconds
Time After: 0.04780 seconds
Time Taken: 0.00246 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.04460 seconds
Time After: 0.05196 seconds
Time Taken: 0.00736 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.05941 seconds
Time After: 0.05961 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.06265 seconds
Time After: 0.06404 seconds
Time Taken: 0.00139 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.05877 seconds
Time After: 0.06423 seconds
Time Taken: 0.00547 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.10642 seconds
Time After: 0.10657 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.67666 seconds
Time After: 0.67858 seconds
Time Taken: 0.00192 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
End call of global.php: 0.68078684806824
Time Before: 0.71108 seconds
Time After: 0.71130 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.71712 seconds
Time After: 0.71865 seconds
Time Taken: 0.00153 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=87748'
WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.74510 seconds
Time After: 0.74532 seconds
Memory Before: 5,997.453 KB
Memory After: 5,997.695 KB
Page generated in 0.74407291412354 seconds with 9 queries, spending 0.008742094039917 doing MySQL queries and 0.73533082008362 doing PHP things.
