Time Before: 0.02426 seconds
Time After: 0.03182 seconds
Time Taken: 0.00757 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.03195 seconds
Time After: 0.03235 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.03255 seconds
Time After: 0.03268 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.03343 seconds
Time After: 0.03605 seconds
Time Taken: 0.00262 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.03275 seconds
Time After: 0.04035 seconds
Time Taken: 0.00760 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.05157 seconds
Time After: 0.05202 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.05418 seconds
Time After: 0.05580 seconds
Time Taken: 0.00162 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.05089 seconds
Time After: 0.05602 seconds
Time Taken: 0.00513 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.09340 seconds
Time After: 0.09352 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.15026 seconds
Time After: 0.15150 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
End call of global.php: 0.15352201461792
Time Before: 0.17713 seconds
Time After: 0.17727 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.18346 seconds
Time After: 0.18489 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
SET lastactivity = 1772634130, location = '/forums/private.php?do=newpm&explain=1&u=87847', badlocation = 1
WHERE sessionhash = '600503b925d08d481e162d46884ab830'
Time Before: 0.20999 seconds
Time After: 0.21036 seconds
Memory Before: 5,998.055 KB
Memory After: 5,998.250 KB
Memory Used: 0.195 KB
Page generated in 0.2088770866394 seconds with 9 queries, spending 0.0085031986236572 doing MySQL queries and 0.20037388801575 doing PHP things.
