Time Before: 0.00262 seconds
Time After: 0.00326 seconds
Time Taken: 0.00064 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.00333 seconds
Time After: 0.00381 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.00403 seconds
Time After: 0.00415 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.00486 seconds
Time After: 0.00715 seconds
Time Taken: 0.00229 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.00419 seconds
Time After: 0.01065 seconds
Time Taken: 0.00646 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.01296 seconds
Time After: 0.01337 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.01478 seconds
Time After: 0.01599 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.01230 seconds
Time After: 0.01619 seconds
Time Taken: 0.00388 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.02281 seconds
Time After: 0.02297 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.03143 seconds
Time After: 0.03266 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
End call of global.php: 0.034398078918457
Time Before: 0.04074 seconds
Time After: 0.04090 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.04296 seconds
Time After: 0.04455 seconds
Time Taken: 0.00159 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=88031'
WHERE sessionhash = 'a1024cf3a534e5ec94f7248e61d8a1ae'
Time Before: 0.05865 seconds
Time After: 0.05892 seconds
Memory Before: 5,997.453 KB
Memory After: 5,997.695 KB
Page generated in 0.057708024978638 seconds with 9 queries, spending 0.0078997611999512 doing MySQL queries and 0.049808263778687 doing PHP things.
