Time Before: 0.02470 seconds
Time After: 0.03032 seconds
Time Taken: 0.00562 seconds
Time Before: 0.03045 seconds
Time After: 0.03091 seconds
Time Before: 0.03118 seconds
Time After: 0.03134 seconds
Time Before: 0.03224 seconds
Time After: 0.03495 seconds
Time Taken: 0.00272 seconds
Time Before: 0.03142 seconds
Time After: 0.03981 seconds
Time Taken: 0.00839 seconds
Time Before: 0.04651 seconds
Time After: 0.04688 seconds
Time Before: 0.04829 seconds
Time After: 0.04949 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.04574 seconds
Time After: 0.04971 seconds
Time Taken: 0.00397 seconds
Memory After: 2,261.719 KB
Time Before: 0.07338 seconds
Time After: 0.07352 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.08851 seconds
Time After: 0.08995 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.092306852340698
Time Before: 0.10105 seconds
Time After: 0.10139 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.10372 seconds
Time After: 0.10517 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=88115'
Time Before: 0.12530 seconds
Time After: 0.12565 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.12415790557861 seconds with 9 queries, spending 0.0086319446563721 doing MySQL queries and 0.11552596092224 doing PHP things.
