Time Before: 0.00156 seconds
Time After: 0.00226 seconds
Time Taken: 0.00069 seconds
Time Before: 0.00232 seconds
Time After: 0.00302 seconds
Time Taken: 0.00070 seconds
Time Before: 0.00327 seconds
Time After: 0.00341 seconds
Time Before: 0.00403 seconds
Time After: 0.00665 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00345 seconds
Time After: 0.00999 seconds
Time Taken: 0.00653 seconds
Time Before: 0.01201 seconds
Time After: 0.01238 seconds
Time Before: 0.01485 seconds
Time After: 0.01611 seconds
Time Before: 0.01138 seconds
Time After: 0.01629 seconds
Time Taken: 0.00491 seconds
Time Before: 0.02227 seconds
Time After: 0.02253 seconds
Time Before: 0.02451 seconds
Time After: 0.02580 seconds
End call of global.php: 0.027423143386841
Time Before: 0.02883 seconds
Time After: 0.02911 seconds
Time Before: 0.03118 seconds
Time After: 0.03264 seconds
SET lastactivity = 1776533347, location = '/forums/private.php?do=newpm&explain=1&u=88164'
Time Before: 0.04524 seconds
Time After: 0.04552 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.044280052185059 seconds with 9 queries, spending 0.0086526870727539 doing MySQL queries and 0.035627365112305 doing PHP things.
