Time Before: 0.01102 seconds
Time After: 0.01328 seconds
Time Taken: 0.00225 seconds
Time Before: 0.01337 seconds
Time After: 0.01385 seconds
Time Before: 0.01412 seconds
Time After: 0.01423 seconds
Time Before: 0.01501 seconds
Time After: 0.01764 seconds
Time Taken: 0.00262 seconds
Time Before: 0.01431 seconds
Time After: 0.02200 seconds
Time Taken: 0.00769 seconds
Time Before: 0.02783 seconds
Time After: 0.02830 seconds
Time Before: 0.02981 seconds
Time After: 0.03104 seconds
Time Before: 0.02715 seconds
Time After: 0.03124 seconds
Time Taken: 0.00409 seconds
Time Before: 0.05416 seconds
Time After: 0.05437 seconds
Time Before: 0.06947 seconds
Time After: 0.07080 seconds
Time Taken: 0.00133 seconds
Time Before: 0.07670 seconds
Time After: 0.07689 seconds
Time Before: 0.07914 seconds
Time After: 0.08067 seconds
Time Taken: 0.00154 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=88175' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.09651 seconds
Time After: 0.09686 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
